I have an air vent in a wall in one of my downstairs rooms. Behind the vent is a Studor vent. On the other side of the wall is a small bathroom.
About a year ago this room started having a smell like the one that occurs if no one has been living in a house for sometime, but more acute. I've tracked it with my nose to this vent.
Any ideas what it might be? I don't think it smells musty... It's like someone ground up drywall.
This looks like an air admittance valve. While not common, these can fail in an open state. You could be smelling sewer gasses escaping from the stuck open valve.
When I had one of these stuck open, it was very obvious that sewer gasses were escaping, and I could temporary close the valve by "tapping" on it with the back of a screwdriver. This was only a short term solution, and the valve was replaced to prevent it from happening again.
  • This doesn't seem like a typical sewer smell.... Can sewer gases have different smells?
    – Julian
    Commented Jun 21, 2017 at 22:52
