I have an old GE central heat and air unit. I have gotten a universal motor to replace the old fan/blower motor. The wire colors don't match up. The unit has white, blue, yellow, and black. The motor has the two brown to capacitor, red, white, yellow, blue, and black. I need help making them work.
    Isn't there a wiring diagram printed on the motor?
    – Tester101
    Commented Jun 17, 2017 at 15:37
  • Can you post a photo of the unit's wiring diagram? Commented Jun 17, 2017 at 15:51
Is this a belt drive or direct drive motor? If you look on the motor there should be a wiring schematic/diagram. If it is a direct drive, the colors determine the shaft speed or the RPM. Usually, Black is high, Blue is medium high, Yellow is medium low, Red is low. Or Red and Yellow could be interchanged. White is the neutral. look on the motor or wiring cover plate. The unused wire is taped off Yours is probably; black to black, blue to blue, furnace yellow to red or yellow, and white to white. Tape off the last wire. However check the wiring schematic just to be sure. If it a belt drive you will need a wiring schematic. Is the motor a single speed or multi speed? If you are not sure how to hook up the motor seek professional help.
