I fear the weight level in my closet on the cheap thin metal rod and need to support it in the middle.
I bought a metal support bracket and the support part of the bracket doesn't meet the rod, it's lower than it.
Do I keep shopping for a match or is there an alternative method here?
This is just holding it against the wall as a test fit (not drilled into wall):
edit:
I've been asked to add a few more pics.
The bracket itself is not adjustable; or I wouldn't be here asking this question. The diagonal rod is spot welded by the manufacturer (STANLEY).
The rod itself is metal and uses one of these round inserts that I screwed into the wall. Oh, and the round thing the rod sits in is not going anywhere; i stripped all the bolts in it upon tightening by drill =(
