I have a single dining room light controlled by two 3-way switches (Switch 1 and Switch 2).
The way things are wired / set up right now is:
Switch 1 is really the only switch we ever use to turn the light on and off.
If Switch 1 is in the On position you can turn the light off using Switch 2, BUT
If Switch 1 is in the Off position, then you CANNOT turn it on using Switch 2.
That said, what I want to do is replace Switch 1 with this single pole dimmer switch. I DO NOT care about being able to turn the light on and off using Switch 2.
The following pictures show the current wiring for the (non-dimmer) three-way switch (Switch 1) and the single pole dimmer switch I want to replace it with.
How would I go about wiring things to accomplish what I want?
