Is there a way to replace a toothbrush holder tile? This is ceramic or porcelain crica 1948.enter image description here
The attempt to glue made the situation worse.
Yes, but it will require a hammer, chisel and a grinder. Expect a lot of dust. The brush holder is still available, so you will be able to get a replacement. Once the old one is out, it is held in place with grout.
You will need to start with a grout saw to remove the grout in the joint between the holder and surrounding tile, it will lessen the chance of chipping the neighboring tile.
  • Is it a DIY job or best left to the pros?
    – EagleBahn
    Jun 10, 2017 at 18:05
    If you have never handled tile it may be best for the pros, Tile removal without chipping other tiles requires a bit of expertise. The task could easily expand into a tile repair as well.
    – Jack
    Jun 10, 2017 at 19:07
    Pretty much depends on the DIY-er. It's do-able, but (like many other things) if you're not comfortable doing it, it may be advisable to hire someone - but check references carefully, some folks do tile professionally but not very well.
    Jan 18, 2021 at 23:15
