I have a split system with 36,000 btu capacity, split over three indoor head units. For the first 5 years worked flawlessly quickly generating tons of heat and cold from startup. Since the end of last summer, it can take 20-30 minutes for the head units to start doing anything and when they do, it never blows that cold or hot air, just mildly cool or warm.
I had a hvac guy come out and he said the temperature difference between the high and low pressure lines by the compressor were 20 degrees apart which he says is good (I have no idea) nevertheless it doesn't blow cold or hot air. I think I need a new hvac guy.
But until I find one, can this simply be a refrigerant leak and it needs to be charged and the leak plugged? Or is there something simpler I can look for?
