So I did a silly thing this weekend while digging out a tree root/stump... I managed to partially (1/3) cut through the buried pipe that runs down our garden to feed an outside tap. (Fortunately it is easy to isolate just this pipe!
How can I fix the pipe?
Is there something I can put over it or do I need to cut it completely and put some sort of joint in? If I need to put a joint in, what should I use? Is there any special considerations given its buried?
