I am building a small (14'x12') detached deck to be placed directly on the ground with some gravel under it. I am using 4x6 pressure treated boards (UC4B) for outside frame.
I intend to use 6" TimberLOK screws from FastenMaster to stitch the frame together. All resources suggest that it's as good as lag screws.
As I put boards together, I noticed the bent on one 14' board. That makes about 1" gap between outer frame and inner joist in the middle (also 4x6).
I wonder if it's ok to use couple 6" TimberLOKs to just pull the outer board to the middle joist.
This picture is to give an idea of the project.
