The issue is this sprinkler was placed in a very bad location. It's next to a large stone and 1 foot away from a 40 foot tall tree.
Over the years, the tree grew on top of the sprinkler pipes. I had to spend 4-5 days figuring out where the leak was coming from. And finally found it. But it's LITERALLY between a rock and a hard place!
I've watched tons of videos on PVC pipe repair, but all the examples are shown in a much more workable and open area. So you can cut the pipe, get new fittings and glue everything together again. Here we can see that I only have this much space to work with. I'm thinking my best bet is repair the cracked pipe somehow and seal the leak. I know the pipe is being bent, but I don't have many options without removing the tree. Which isn't going to happen, I simple can't afford doing that right now.
Large Size image: https://i.stack.imgur.com/vTD3g.jpg
If you guys have any legitimate long term solutions, I would love to hear them. I'm thinking about leaving this hole open for the forseeable future, because it's literally in the back corner of the properity and no one will ever see it. That way I check on the pipe from time to time.
