Just installed fire pit and now getting a whistling sound in the house when fire pit on full range .I'm going to explain what type of pipe and size of pipe..... 4 years ago decided to build a outdoor kitchen during my construction had 1/2inch pipe coming out of my home so I tapped into that using flex tube to black pipe and made connection to bbq worked flawless... and now I was able to build an a fire pit ...now on this construction project I tapped into the existing 1/2 inch pipe from my Bbq .... so what I did was run a tee down with 2 turn off valves ... one valve ging bbq and the other going to the fire pit All this is 1/2 pipe till after the tee split fron there it goes 3/4 flex tube to 3/4inch green gas pipe roughly going out 15feet to my 4x6 fire pit .... the burner is a 3feet by 10inch wide . Not sure if this is normal operation , can someone please explain in if this is okay or will I some professional help in this. Thank you .
  • The 1/2" pipe is too small for what you are doing. You should have run 1" pipe from the main house line and teed off that to each appliance. If a 1" connection is not available where you tied the 1/2" line for the outdoor kitchen, you may have to change some of the main house line. You may be able to run 3/4" instead of the 1" i mentioned, but if I were doing it I would use 1" to make sure I have a large enough line for the appliances I am connecting to it.
    – d.george
    Commented May 31, 2017 at 10:23
  • D. GEORGE THANKS FOR THE REPLY MY APPRECIATED.... SINCE MY LAST POST I'VE BEEN RUNNING THE FIRE PIT ONLY TO BE HEARING THE WHISTLING SOUND IT'S NOT NOTICEABLE TO THE AVERAGE JOE. BUT I CAN HEAR IT .... NOW WILL THIS SOUND CAUSE ANY ISSUE IN THE LONG RUN? Commented Jun 13, 2017 at 18:21
I'm assuming when you say "flex tube", you're talking about a flexible gas connector like this.
If so, the whistle could be caused by this connector. You should be able to find "Whistle-free", or "non-whistle" gas connectors, if you search the internet. The other option, is to use rigid plumbing the whole way.
As d.george points out, you'll want to check the manufacturers documentation for the fire pit burner, to determine if the gas plumbing is properly sized. 1/2" is usually only good for a single appliance. You'll likely have problems if you run the BBQ, and the fire pit at the same time.
  • Thanks for the response to my questions... I was able to run the fire pit and the Bbq at the same time witj no problems.. also I did to some reach and found you are correct about the flex tube line its what is causing my issue .... so now my question is will this have any reproduction to my system? Commented Jun 13, 2017 at 18:18
  • @JoseIniguez "any reproduction to my system"???
    – Tester101
    Commented Jun 13, 2017 at 21:53
