I have a walk in attic. Through a room upstairs, there is a door that opens and you can step out into the attic. There is a power outlet in the attic on the wall (on a stud) near that door. What I'm wanting to do is keep a POE switch in the attic. I would need to run an extension cord around a corner from that outlet in the attic to put it where I want to put it. The area has particle board below it, studs with insulation on 2 sides, and open area on the other two sides. My concern is that I want to make sure I'm not creating a possible fire risk. I don't think I would be, but I would like some feedback by people who know more than I do.
I tried to upload pictures, but they're apparently too large ...
By the way, my question is not with the CAT cables. I have in wall rated CAT6 cables already running to a switch that is in a closet. I want to reroute those cables to this attic switch to make things easier for me, and cable runs shorter.
