Henter image description here
Can I just replace the bulb or do I have to replace the entire assembly? Does the bulb just unscrew or is there a spring mechanism? Also what type of bulb is it? I'd like to replace it with a bright led
The bulb will just unscrew.
That's currently an R30 CFL bulb. Probably about a 65w watt equivalent.
You should have no problem replacing with LED.
