There's a kind of a gap between the asphalt and the garage which causes moisture to accumulate there.
I'd like to seal that gap by making a tar joint:
https://www.homedepot.ca/en/home/p.sealant-asphalt-black-300ml.1000409856.html?autoSuggest=pip[
How should I proceed with this? Is it a complex job? Do I first need to clean the gap as much as possible? What do I need to watch out for? And so on.
Thanks in advance for your kind help.
