This is my first remodel attempt and I would like to create a doorway between a bedroom and a walk-in closet. The existing wall between the two rooms is a load-bearing wall. After removing the sheetrock, I see that the existing configuration is actually a remodel from a previous floor plan where a doorway used to be in almost the same place that I would like to place my doorway.
I would like the shift the doorway a foot or two to one side, however, I see that there is a concrete piece under the base plate (see picture below).
Concrete under wall (left), 2x4 under previous door (right)
What is this concrete piece and can it be removed?
    we need to see the top of the wall and the whole wall to get a better understanding. – Alaska Man May 21 '17 at 16:32
  • looks like a cinder block as part of the load bearing structure. – ratchet freak May 22 '17 at 8:42
  • Yes, it is cinder block. Can it be removed without compromising the load bearing qualities of the wall? – Randy May 22 '17 at 12:53
