I am working on my first wood product. I am completely new to this. The following happened:
My question is: How do I stabilize this crack?
Can I fill something into the hole so that the crack doesn't get any worse?
Sign up to join this communityPut glue-ca or wood glue in now, back out the screw and then predrill and lightly countersink so the screw will hold but not force wood apart.
The rule with splits or breaks like this is
Don't skip #2 or you'll have wasted the glue. Clamping forces the glue into the wood, and it will be a stronger bond when cured, than the wood alone would be.
I would remove the screw, glue, clamp, and then take a drill bit the size of your screw head and chamfer the hole (just rev the drill and press lightly to let the drill cut a bevel where the head will sit). The chamfer should ensure it doesn't crack when added again.
contact us
link at the bottom of the page, thenI need to merge user profiles
from the dropdown and follow the instructions. You'll need to provide a link to the unregistered account profile. It might take a few days for the request to be processed (it's the weekend ATM). – Niall C.♦ May 20 '17 at 16:24
