I'm trying to replace an old standard receptacle with a new GFCI receptacle as well as a switch to a set of lights next to it. The switch should not control the receptacle (outlets should have power regardless of switch).
Currently, the GFCI receptacle works when the switch is off. However, once I flip the switch, the receptacle trips and the lights do not power on. There are two cords coming into the electrical box.
Each cord has three wires that are black, white, and green (Cord A's green is mostly non-insulated). I'll refer to Cord A as the one of the left and Cord B as the one on the right.
Note that Cord A's black wire is stripped in the center and then continues to the GFCI receptacle. This is how it always has been.
I have been connecting the center-stripped black wire from Cord A and the end-stripped black wire from Cord B to the single pole light switch. I have tried grounding Cord A's green both with the switch and the receptacle. Same result either way.
For the receptacle, the end of Cord A's center-stripped black wire and Cord A's white wire are connected as line. Cord B's white wire is connected as load. Note that there is no other black wire to connect with load. I have tried swapping the white wires, but then the receptacle doesn't work at all.
Any suggestions would be greatly appreciated. Thank you!
