I currently have a spare phone battery that I am using to power my child's mobile. My question is how can I add a useful way of charging the battery without removing it? Is it possible that I could solder a female USB port to the battery and mount this inside the mobile and then using a typical USB mains charger, charge the battery up that way? The mains unit only outputs 5V at 2.1A.
I'd rather ask instead of blowing a Li-Ion battery!
  • You might have better luck at electronics.stackexchange.com. Your question is somewhat off-topic here. That said, you need something more intelligent than just a voltage source to prevent overcharging, which can be dangerous. – isherwood May 17 '17 at 20:10
  • You might purchase an inexpensive third-party standalone charger for your particular battery model. – isherwood May 17 '17 at 20:11
    Improperly charging Li-Ion batteries (as you're proposing) results in fire. Ask me how I know ... – brhans May 17 '17 at 20:11
    Doesn't the mobile already have a method to charge the battery? If it does, then why would you solder a USB port on the battery and then mount it inside the mobile? Just use the mobile's normal charge method to charge it. Soldering anything to a LiIon battery is not recommended without special techniques/equipment since you can destroy the battery, sometimes catastrophically. – Johnny May 17 '17 at 20:19
    I wouldn't use a lithium battery anywhere near a child. NiMH is a much more docile battey and actually comes in the formfactors kids' toys tend to use. – Harper - Reinstate Monica May 17 '17 at 22:30
I did something similar for my kids' rocking swing, only I bypassed the battery. Find one of the 64 old phone chargers you have around that matches the voltage and current requirements of the mobile, and connect that to the battery box. (You did save all those proprietary Motorola and LG flip-phone chargers for hobby projects, right?)
You can either solder directly to the terminals, or solder to a couple metal plates that you hold in place with a battery-sized dowel. This way you can use batteries again later if you like. Consider installing a fuse inline with the positive wire for added safety.
| improve this answer | |
  • yeah you just had to throw that in about every one having their own unique power cord even from year to year... :-) – Ken May 17 '17 at 21:32
You can't. Li-ion batteries require very careful monitoring during both charge and discharge, otherwise it's a fire hazard. Phone battery should be only used in the phone it came with, because it's the phone that has all the circuits for monitoring charge and discharge.
But you should go with isherwood's advice and remove the battery completely, if you don't need the mobility. If you don't want to solder the toy, you can make great battery-to-wire adapter by using a round wooden stick of same diameter, cut to length and with a thumbtack placed on the end to serve as contact.
