We just purchased a house and I want to run low-voltage cables (Cat6 + RG6) from the basement to the attic. I have a good route up a 10"x18" chase currently occupied by only a few water pipes, which leads to a second-floor utility closet from which I can run directly to the attic.
The problem is that getting up to the chase from the basement requires running the cables under the duct of a bathroom exhaust fan, and from the side of the wall where I currently have access, I don't think I'm going to be able to successfully pull the cables without inadvertently damaging them on a support bracket or ending up with too small a bend radius.
I can get access directly under the chase in order to pull the cables and ensure they clear the duct and have the proper bend radius, but such access from below will require cutting a hole in the ceiling at the back of a shower stall in a basement bathroom. Given the location, I have some concerns/questions:
1) Is this a really bad idea? Since I haven't cut it yet, I don't know yet what water/moisture-proofing measures are in place--my view from an inspection camera suggests there is nothing but drywall--but I don't want to create a world of pain for myself if making this hole is going to be hard to patch.
2) Since I would like the option to run additional cables in the future, I was thinking of putting an access panel in the ceiling rather than just patching the drywall. Are there products that would be appropriate for this environment, or is that asking for trouble as well and I would be better off cutting and patching drywall?
I hope I explained my situation clearly enough.
