the seller of the house I purchased removed the above ground pool, there is a 17 by 26 feet opening that is about 6 inches deep. 221 ft3. There is a thin layer of packed down sand which has smaller rocks around the edge. I'm interested in filling and converting the hole to a patio.
What material would I need to fill the whole as a solid base.
  • What type of patio would you be putting over top - concrete, stone, etc? It's very likely that you will need some sort of base / drainage for the patio, which would fit (at least partially) in the existing hole.
    – mmathis
    May 9, 2017 at 21:54
  • Hi @mmathis. I would probably use large square pavers in the center to make a square. The shape of the ditch is an elongated hexagon (pool shape). So I would fill the whole with the. See, then create the patio starting in the center with a square/rectangle shape around the center.
    – Technupe
    May 10, 2017 at 17:27
3/4 minus crushed quary makes a great base for just about any type of patio. I use a plate compactor and have finished with pavers and poured concrete in the past with excellent results. I would caution not to use crushed river rock as it will not lock together as well and tends to move around compared to crushed quarry rock.
  • Is it a diyer, type job, I can follow instructions and have done so all around my house. One question I have is do I need to remove the existing sand first?
    – Technupe
    May 10, 2017 at 17:28
  • It depends on how deep the sand is if only an inch or so the rock will settle in the sand. If it is deeper sand I would pull most of it to the side put my rock down then put the sand on the rock and pack it wet this will make an awesome base.
    May 10, 2017 at 18:33
