Is it appropriate to rebuild brick steps with sandstone slab steps and landing depicted with dimensions in the picture "Final Constructed Steps" below using the original construction method depicted in "Brickwork Construction Details"? I am getting conflicting advice from contractors I am looking to hire (two say it's good, a third says it's bad and destined to fail) and I cannot find good resources on whether this method will hold up in the long term.
Final Constructed Steps:
Finished Steps
Note: Hand railings not depicted in this image, but will be present as required by code.
Also, the 16" width is the size of the stone slab, the exposed tread is roughly 12" because half bricks (8" length) are covering the rear of each 16" slab to provide support to the next slab.
Brickwork Construction Details:
Construction Method
Each sandstone slab supplies the base to support the front of the next stone slab. The middle and rear of each sandstone slab are left unsupported.
More details on why I ask:
My steps have deteriorated over the years using the depicted construction method. It has lead to bowing in the sandstone (Possible to salvage bowed sandstone slabs for porch steps?) over the 60 years of my home's existence. However, the front foundation wall for the first step was being pushed out by the earth and allowed the bottom step a lot of movement until I recently repaired it, so it may not have been entirely the fault of the original construction method.
That said, since sandstone is prone to bowing if left unsupported (as confirmed by discussion with several contractors), it seems like the original construction method may be weak in several areas. However, I have had two quotes from masons suggesting the same original method with new sandstone slabs and one quote from a more generalized builder who said I should have support the whole way across (build up the foundation and support each slab the whole way across with brick or equal sized material). I asked each about adding lintels to support the rear of each slab step and none of them thought that was a good idea (the masons thought it overkill and the generalized builder thought it insufficient). The method suggested by the generalized builder seems extremely sound, however it also is quite a bit more expensive. If the original construction method is truly adequate (provided no more foundation issues), then I would prefer to save some money to use on other projects and not needlessly overbuild my porch steps
  • BTW, if you still have the original stones, even if bowed, they could be cut into smaller stones with a diamond blade. Besides being more manageable, any existing bowing would become relatively unimportant in the smaller pieces. If they are supported on a paver and sand base and any of that settles, you won't be back at unsupported, bowing stones. The smaller, multiple stones will just adjust with it (and be obvious). The stones can be pulled up, and more fill added (better long-term solution)
    – fixer1234
    May 8, 2017 at 21:27
Some thoughts:
  • Single stones that size will be ridiculously heavy. Consider using three stones per step, similar size stones for the landing.
  • You don't need solid brick under the stones, but you need something. You could compact fill dirt for bulk filling, then a layer of paver base, and top with a layer of sand under the stones at each level. If you really wanted to get fancy, you could run a couple of rows of brick supports lengthwise, so they would support the seams if you use three stones per step (and fill as described in the cavities).
  • In terms of dimensions, the steps should follow a ratio of 2 x rise + tread = 26 to 27 inches. If those are standard bricks, your dimensions will not feel natural, and people will have trouble walking them with a normal gait. It would be closer if you rotate one brick on each side of the lower steps so that the tread is 12" instead of 16", then add a brick to the landing to maintain the total length if needed. But it's only three steps, so it may not be a big deal.
  • Concrete blocks might also provide added support, at a discount rate.
    – Tester101
    May 8, 2017 at 11:14
