My pressure pump that goes to a bladder tank has a small hose. It was off and water leaked everywhere. I put it back on. After I turned everything off and then turned water on in house. After about 15 minutes it was sucking air again.
What's wrong? It's hard to check because my well is far from the house. Should I turn the pump off? I have a 500 gallon holding tank. Should I check for a new pump?
The pressure came back up in the bladder, then when that water was used there was no more water in house.
