Halftone and op-art caught my eye, and a local opportunity could provide a good source for a tile project. It would comprise two different colors of tiles, with identical size and dimensions.
The halftone pattern would be made by cutting corresponding tiles to make a new whole, i.e. 20/80, 30/70, 50/50, 70/30, 80/20. For example, pretend that each [bracketed] group below represents a compound tile, made from fractions of cut tiles.
[00000+] [0000++] [000+++] [00++++] [0+++++]
these examples show related effects
https://uk.pinterest.com/pin/550987335644152321/
The cuts can be made horizontally or diagonally at varied angles, as long as the bisecting line passes across the entire width of each tile. This will leave a uniform space for grout in every possible ratio of tile fractions, and provide a uniform size of each compound tile.
The floor would be installed in a bathroom of a house where I live. However, I might rent the space some day, and don't want to install anything that would spoil a deal for a potential tenant. DAE know an example of halftoning done tastefully, without looking garish or odd? Selecting two tile colors that don’t substantially differ from one another might tone down the effect, and make a subtle transition from one color to the other.
This project demands many cuts, careful attention and much time, so I don’t want to begin unless I have a better idea of how well it might go.
Tl; dr – how can I properly do a halftone tile project, so I can avoid a noisy eyesore that will repel tenants and require expensive rework?
