My house downspouts often get clogged with debris. Is it possible to clean them without getting on a ladder or on the roof? I was thinking about snaking my gutters. I made a quick trial using a garden hose and also a plumbing snake. Neither worked out. Is there a lighter weight snake type option available (I don't want to rip off my downspouts)
Do you mean you want something you can feed up a downspout that will then make a right angle turn and clean solid debris out of the length of a gutter?– feetwetApr 25, 2017 at 21:43
That's what I was thinking.– Dan SApr 25, 2017 at 22:34
I suggest some gutter mesh panels as a preventative measure. The cheap clip-on ones from the big box stores actually do very well against my many white oaks, which drop twigs and leaves by the bushel.– isherwoodApr 26, 2017 at 1:49
1Are you asking about the gutters or the downspouts? Your question contradicts itself. Please edit the post and title to clarify.– isherwoodApr 26, 2017 at 1:50
There is an adapter that connects the output of a leaf blower to the bottom of the downspout and blows the debris back out the way it came (sometimes you can even do it without an adapter). It works pretty well if it is a recent accumulation. Note, though, that you will get covered in a shower of disgusting stuff (gravity working for you).
But if it has been decomposing for several seasons and turning into a solid block of adobe filling the inside the downspout, that may not work. In that case, the snake and hose is probably the tool of choice to try first. Smacking the downspout in the vicinity of the clog can help loosen it.
They make a special nozzle for the hose that puts out both a high pressure forward spray, and side sprays that also spin the nozzle, creating a rotating jet of water that helps to break things up and wash it out. It can be a long slow process that will raise your water bill and flood your yard, turning it into a mud field by the time you're done.
Sometimes the fastest solution to stubborn downspouts is just to start taking sections apart. A few screws and a section comes off. Clogs tend to build from the bottom up so if you're lucky, the bottom-most section will either do it, or make it easier to get the rest out by simpler means. Once a section is removed, low tech smacking, blowing, or pushing is usually enough to clean it.
I saw a "J-shaped" garden hose adapter for this very purpose advertised a few months ago, but didn't save the name. I was thinking of something like this too, but I have screens inserted into the downspout where it connects to the gutter, so I guess I'll be climbing that ladder for a few more years.
