So, I'm a little stumped on this one. I've installed laminate over a pad, but because of the way that the boards click in and the fact that it's a floating floor, the parts that end near the edges (particularly the last row that runs parallel to the wall) has a little bit of bounce to it. Not really anywhere else, just the last row because it's not on a laser level subfloor (concrete basement) and the pad itself has some squish to it.
So the problem is, when you step on the last board it travels a little bit. I can install the baseboard tight to the laminate (still allows it to slide under the baseboard for expansion), but even then it still produces a squeak with the subtle friction between the baseboard and the floor board. I could install the baseboard loose, but then the last row would move up and down (which would be a little weird) and I'm guessing whould "whack" the base if I put it up too high.
What's the right way to do it? Most instruction I see just say "nail your baseboard up and have a drink" and the ones that actually say anything usually say to keep the base tight (though many are for wood floors that don't flex so much).
The last board is not secure to the wall ,and has plenty of movement - buy some talcum powder aka baby powder and place that under neath your floor boards and between the racks (joints) . It will act as a lubricant. Secure your baseboard tightly.
Here is a link you can read more about it.
