I have a leaked cpvc pipe and I asked a question the other day. bathroom pipe joint leakage behind the ceiling tiles, now I am searching a new pipe for replacement, I thought the pipe is 3/4", as shown below (if you enlarge the image you might be able to see the spec of dimensions)
Therefore I went to Lowe's and bought a 3/4", and it turned out to be bigger, then I changed to 1/2" and it's still a little bigger. So what's exactly the right size?
