I have a universal electrical motor (for a home wall fan) that came shipped with a Lutron 120v 5amp rated slide dimmer control to regulate it's speed.
No rating listed on the motor itself. Two wires (and a ground) coming out of the motor casing.
Is it possible/practical to build my own 3 speed, pull switch control?
I am guessing that I would just need to get two, proper resistors with matching heatsinks and wire them to a 3 way switch.
One circuit open. One circuit no resistor. Two circuits with varying resistors to lower the fan speed.
It seems that no such thing exists for sale...
And, although I have done plenty of off-the-shelf installation of auto & home electric, I have never created custom circuitry like this.
Thank you much, Nathan
migrated from electronics.stackexchange.com Apr 23 '17 at 23:46
This question came from our site for electronics and electrical engineering professionals, students, and enthusiasts.
  • the dimmer doesn't use resistors, and neither should you; that's a fire hazard as-described. if i were you, i would use the existing dimmer on whatever "medium" setting i want, then use the switch to choose between disconnected, connected via the dimmer, and connected via un-altered AC (yielding off, low, high). add a 2nd dimmer if desired. – dandavis Apr 21 '17 at 9:12
  • Read the article on Wikipedia for a Universal Motor and you will see they don't use resistors to control the speed. This hasn't been done since the very very old days of controlling the speed of a D.C. motor. en.m.wikipedia.org/wiki/Universal_motor – ArchonOSX Aug 12 '17 at 10:08
