My two Duravit Starck 2/Happy D toilets have turned me into a full-time toilet scrubber. Any suggestions before I replace them?
The problems:
  • Fecalpheliac bowls. "Matter" seems to stick tenaciously on the bowl. I must scrub the bowl after each and every usage.
  • Poor flushing. I must flush two and sometimes three times to clear the bowl. So much for "lo flush" water conservation.
  • Long refill times. One toilet takes 90 seconds.
What I've done:
  • Cleaned the fill lines and filters.
  • Adjusted and re-adjusted the fill levels in the tank.
  • Had a plumber examine the bowls. He said "It's a shame - they're so expensive."
  • Asked my Duravit supplier. Their answer: "Most Europeans use a scrub brush."
  • Written scathing "Happy D" reviews - "SAVE YOURSELVES! It's too late for me!"
In short: Pretty to look at. Awful to use.
  • I have seen TV commercials for a product that is sprayed into or poured into the toilet bowl before use which is advertised to prevent feces from adhering to the toilet inside surfaces. As I have aged I seem to foul the toilet surface significantly more than when I was younger. (But this is far from the worst difficulties of being in the 8th decade of human life.) I keep a large squeeze bottle of water near the toilet and squirt a jet of water on adhering matter to dislodge it. Maybe $5 for the bottle. Not perfect but is an improvement. Keep searching for a solution short of replacement. Apr 23, 2017 at 12:50
I do not know anything about your toilet, but I have 2 types in my house. I have 2 Kohler Cimarron 2 model K4421 which are great and a new American Standard Champion 4 max just recently installed. The American Standard is supposed to be able to flush a bucket of golf balls. Don't tell my p..p that. It doesn't always go down completely. I would choose the Kohler. Also we use " never scrub " cartridges to help keep the bowl clean.
  • I've noted your recommendation of the Kohler. I'll try NeverScrub. Thanks! -Scott Apr 24, 2017 at 10:46
