Looking into remodeling a basement in a major US city. The basement height is too low to meet code and I have been told that it is extremely unlikely that the city would grant a variance. I have talked to 4 contractors/design companies and none of them have any problems with not pulling permits for the job. These are all established companies with licensed contractors who use licensed sub-contractors. Can a licensed contractor perform work, that requires a permit, without a permit?
10
  • 5
    This is a legal question and may be closed as off-topic, but generally speaking the person pulling the permit is responsible for the appropriate completion of the project. By not pulling permits, a builder essentially passes that risk to you. They may not be required to do so by law or statute, but that's for your local offices to say. Call them. From a pay phone. :P – isherwood Apr 19 '17 at 16:42
  • VTC as off-topic, as @isherwood suggests. It varies by jurisdiction, but in general, if a permit is needed, the person / company performing the work is responsible for getting it. Work can obviously be done without the permit (nothing stops anyone from swinging a hammer), but that work would not be "legal". – mmathis Apr 19 '17 at 16:45
  • @mmathis I was thinking this was more of a licensing question than a legal question. If the city found out a licensed contractor was doing unpermitted work, presumably they would not take them to court, but might revoke their license. It may be off topic because it is location specific, but i don't know how contractors are licensed. – StrongBad Apr 19 '17 at 17:04
    @mmathis okay. The distinction between questions about building codes and legal questions is not clear to me. – StrongBad Apr 19 '17 at 17:12
    I'm voting to close this question as off-topic because it is a legal question, not a home improvement question. – Daniel Griscom Apr 22 '17 at 13:32
The way I read your answer does not imply working without permits, and all the answers here are literally going up that tree and is annoying to say the least. ( But I have not down voted any ).
Granted each City varies by what they allow but technically​ the short answer is NO, builders/contractors are not required.
Why you may ask? Simple, because you can sign an affidavit with the City acting as the General Contractor. And voila, you yourself pull the building permit.
Now this is wonderful right? Yes because it saves everyone overhead which equals lower cost, but the catch is now you need to verify all your subs are licensed, insured if necessary, and have workers compensation if necessary. . My bad, the City does the background check for the required license and business license only,, with the exception of the General Contractor since you'd be the general contractor. You'd still need to have proof of insurance and/or workers comp REGARDLESS who acts as the contractor. States vary on workers compensation laws too so do your homework.
Typically for permitting you will need to sign an affidavit with each licensed sub ( electrical, plumbing, HVAC ) to the City stating you are the General Contractor.
By doing the affidavit you take some of the hassle and legal headaches off the builder. Each job varies too. Some times it works out better sometimes it doesn't.
Now, if you decide to opt out and let the contractor do all this, they would provide the City with their business license and state license for contracting. All the licensed trade subs would do the same. For a small job like yours this might be around $2000 in paper work and running around for the contractor. You'd have to discuss that in detail with them though.
You still should do your homework to make sure each subcontractor is licensed with insurance and/or workers comp. Many States offer easy online search tools to find out.
If the work requires a permit - that is a City / State Ordinance [aka LAW]- the answer is while the contractor could perform the work - it is a violation of the Ordinance. It is possible that the contractor might have it in fine print where it requires you to get the permits. They do the work "assuming" you have the permit or are in process. You can check to see if they really are licensed - I doubt a licensed contractor would do anything with out the permits.
This presents two problems:
  1. If you are found out to have done this work with out a permit you are probably going to be required to undo the work.
  2. The other issue you have is in selling the property - changes to the property can be looked into and a buyer or a buyers inspector can check for permits on the property.
    a: In this case you would need to get it permitted in order to sell the property, which winds you back to the possibility of undoing the work at your expense of course.
The Contractor probably requires you to get permitting - somewhere in the fine print so they can cover themselves. In the end you will be out the money you pay to the contractor and possibly more to have it all undone.
Get a contractor who will get the required permits, ask for the variance as it is an existing basement - you just might get it unless you are intending to make the ceiling height lower in your remodel. I assume you are going to put in rooms of some sort or a entertainment space.
if you are turned down , you are turned down; permitting is not expensive - undoing completed work is.
  • I have checked the city's license verification system and they are licensed as general contractors. It seems like there is no penalty to the contractor for not verifying there is a permit. It seems all the responsibility falls on the homeowner to find the "fine print" about what permits are required. Having contractors lose their license for doing incorrectly permitted work seems like it would solve some issues. – StrongBad Apr 19 '17 at 19:11
    We get all the info (plans, specs, etc.) together AND apply AND pay for the permit, but we make the contractor pick it up. When you pick it up they make you sign for it and agree to call for all the inspections. We want them responsible for that...we don't know their schedule. – Lee Sam Apr 19 '17 at 19:29
    @StrongBad find a contractor that will apply , pay and sign for all required permits. Make sure it is in the contract as such. There are contractors that do this..they do it all the time - they might charge more ..but it is worth it in the end. – Ken Apr 19 '17 at 19:38
    If an ordinance requires that permits be conspicuously displayed (as is often the case), I would think that a contractor who did work when no permit was visible could be presumed to have knowingly and deliberately violated the ordinance. – supercat Apr 19 '17 at 23:36
Don't build anything without a permit!!!!
However, the "code" only stipulates the height of "habitable rooms" (7'). Bathrooms, storage rooms, utility rooms, hallways, etc. are not habitable rooms. Habitable spaces are rooms used for living, eating, cooking and sleeping. (R202)
Can you call the rooms: study, kids playroom, closet, etc.?
However, you can't sell the house as a 5 bedroom house if you only have 2 "legal" bedrooms.
Oh, by the way, the new Code is due out in 2018 (I think it gets adopted in September) and I don't know if the same rules apply.
    The op does not state where he lives so how do you know the new code is due out in 2018 you might be referring to fire code. States and Cities have building codes that can vary quite a bit, he might have other factor's at play. But you are correct DON'T BUILD ANYTHING WITH OUT THE PROPER PERMITS. A Good Contractor will get them or tell you why he can't. – Ken Apr 19 '17 at 18:47
    Oh, another great room we use is Work Room. It drives them crazy. – Lee Sam Apr 19 '17 at 19:30
  • I often see them call it a "Bonus Room"... – Harper - Reinstate Monica Apr 19 '17 at 21:15
  • A "study" and "kids play room" are both examples of habitable rooms. If you're looking for non-habitable examples, "closet" is good, also "storage room", "utility room", etc. – Tester101 Apr 20 '17 at 13:53
  • The 2012 IRC 305.1.1, does state that basements areas that are non-habitable shall be no less that 6 foot - 8 inches, with an exception for projections. – RomaH Apr 20 '17 at 21:25
You will need to get the exact legality of this situation from your local building codes enforcement.
But for illustration:
I work as a municipal building inspector for a small city and if I was told of or witnessed a basement finish in progress, I would go to the job site and ask for the building permit. If they did not have permit, I would issue a 'stop work order', essentially you cannot do any more work until you get a permit. And you have to stop work when asked; I have called the city police to enforce a stop order before.
The penalty for not having a permit will vary by jurisdiction but in my city it is double the permit fee. So if your permit was 55 dollars, it jumped to 110 dollars. Depending on the work done, I might have you tear the work out so I can do the needed inspections. That is additional money.
In the end, the City could come after you because you are the owner of the property, not the contractor! You are ultimately the responsible party of many thing when it comes to building safety as the owner. Less scrupulous / fly-by-night / storm-chaser, contractors may be okay with doing work without a permit but they may not be the one on the hook if something goes wrong.
Additionally, as described by @Ken, you may run into other problems when trying to sell the house or getting it appraised later down the line. When a permit is completed and the Certificate of Occupancy/Completion is issued, a copy is usually sent to the county where they adjust your property values and record the improvement; home value changes a lot dependent on number of bedrooms. If an appraiser or home inspector finds that rooms were added without a permit it may hurt your value or cause the buyers to back-out of the purchase entirely. People do check for these permits quite often.
It may be a inconvenient, but getting a permit lets you have some margin of certainty the contractor didn't cut corners that might get you killed or ruin your investment. It will let future buyers know that the property was constructed by best practice. Even if you plan on spending your remaining years in this structure, it will be easier for your children to reap the benefits of your investment with the addition being permitted.
Engineers, architects, and even contractors have spent thousands of hours compiling the International Residential Code to give you a minimal standard of safe housing construction. It wasn't publish with mustache twisting because we get off on telling people how to do something, but to keep people from dying from outdated or faulty practices.
Speak with a Building Official or his representative (could be an inspector), they may be able to suggest alternatives that get you to your goal. Hiring an architect familiar with local codes could help you just as well.
  • I understand the benefits of permits and licensed builders. I was surprised that using a licensed builder was not sufficient to guarantee that the proper permits would be pulled and that it seems I need to do research to determine what permits are requiredoing and when. – StrongBad Apr 20 '17 at 23:24
    In my city there isn't a guarantee that a builder gets a permit. Getting a city license to do the work and getting the permit are too different mechanisms. And revoking licenses are often a legal quagmire that is best avoided. Just do your research and run everything to ground and ask questions before committing any money. – RomaH Apr 21 '17 at 13:03
Has anyone ever answered a question twice? Hmmm...we'll, here goes...
This won't answer your question, but may help you. You may NOT need a Building Permit.
Little known fact: the code is actually divided into two parts: 1) Construction, remodeling, additions, etc., and 2) maintenance and non-structural work. You don't need a Building Permit for maintenance or non-structural work. That's why we don't get a permit for re-carpeting, re-painting, building partitions, etc. Likewise, you don't get a permit for replacing a window (construction) if it's the same size or smaller. However, if it's larger, then you need a bigger header and that is structural.
You still need to get plumbing and electrical permits, regardless if you get a Building Permit or not.
Also, you can't build something that doesn't meet code, but you may not need a Building Permit. What you call the room is important. You can't call a room a "Utility Room" , build an egress window and then put a bed in it.
There are many items covered by a Building Permit like, ducting for a forced air heating system, handrails, guardrails, bath exhaust, etc. But, if you're not installing items like that, then you may not need a Building Permit. (There are about a zillion items like that and you won't know until you discuss your project with the Building Official.)
In fact, I'll often call the Building Official (not a Building Inspector, not a Plan Reviewer, etc.) and ask him if I can't submit something in one way or not. Then, if he doesn't agree, I ask how he'd change it to make it work. You'd be surprised how creative he can be...be sure to ask about partitions. (Here, our town does not require a permit for re-roofing (maintenance), but the neighboring town does (they consider it construction.)
By the way, it doesn't matter what I, or anyone else, tells you...it only matters what YOUR Building Official tells you. For every Building Official you find that says Kids Play Room is not a habitable space, I can find one that says it is. So, don't go in to the Building Department acting like you know everything. Ask questions and let them know what you're doing. They are there to help.
Sorry...this is way off topic from your question...I always get minus marks for deviating from the original topic, but I thought this might help.
    There is no universally applicable code. Your reference to "the code" and specifics in it are therefore incorrect for many readers. In my city, you need a permit for almost everything short of paint. – statueuphemism Apr 20 '17 at 19:32
  • No down vote from me. It is exactly this craziness that makes it hard as a consumer. What I am trying to determine is if I can trust a licensed contractor to tell me when, and what, work requires a permit. – StrongBad Apr 20 '17 at 19:52
  • @StrongBad The best way to determine if your work requires a permit is to call the city or county and ask them yourself. You can then compare the answer they give with the answers your contractors give, and hire accordingly. – mmathis Apr 25 '17 at 17:17
