We're doing a kitchen remodel, and we're prepping to have a tile backsplash installed on one wall, from the countertop to the ceiling. There's a window on this wall, which the sink is centered on. The area of the wall to be tiled (minus the area of the window) is 37 square feet.
The problem is that the wall is uneven. If you put a 48" straight edge up against the most sunken areas, there's a gap of almost a 1/2".
There is also a spot near the window trim where the wall appears to be built up too much, enough so that the tile could end up proud of the trim, which I'm pretty sure won't look so hot.
My inclination is to tear the wall down to the studs and redo it, but our cabinets have already been installed (though not the countertops). There are no upper cabinets on this wall, so I am wondering if it's possible to redo only the part of the wall that is above the level of the countertop?
Or would it be easier to fill the valleys with drywall mud? If so, which type of mud would be best for this application? Are there any issues to consider, like cracking and water exposure? (There will be a sink under the window.)
