I am looking to run two new circuits outside. Initially it was one circuit for a swimming pool, but I figure since I am doing the run to the other side of the yard, I should run another circuit for yard decorations, tools, etc.
I am going to use a GFCI circuit break for both, and I would like to run the same wires in the same conduit. I planned on making the pool circuit 20amps, and the secondary outlet 15amps. I have metal conduit in the house, and would like to lead out of the house from metal conduit to pvc conduit.
1)For inside the house, is it better to run a separate conduit line for these two circuits, or pull through an existing conduit to save time. Here are pictures of the basement ceiling conduit and breaker box, and the corner of the basement I would like to lead the conduit out at. Is there a circuit spot I need to come out of the house at, or any restrictions?
Bring electric out through this corner.
Would like to run conduit along fence line to corner gate, right side. The other trench in picture is for french drain I am installing. The trench would start from left of picture to fence. Pool will be around that corner as well.
Trench start from house
2) with the length of the run, about 75ft outside, and then about 40ft to run the wire from the breaker box to the otherside of the basement, then to outside, should I run 12guage wire for both the 20amp and 15amp circuits to reduce any voltage loss? Also, would the wires be 2 neutrals, and 2 hot, and then coming from the outside, 1 ground? What guage should the ground be?
3) can I come out of the house on an angle to shorten the length then with a 45 degree turn, then straight and then a 90 for 4ft, and another 90 for 1ft run then go up to surface mount..
4) how far above ground do the outlets need to be? And can both circuits sit on the same 4x4 post?
5)Anything else I should know?
I have the permit for the pool approved and I was told the electrical is included. I submitted the permit application before I decided to add the extra circuit. Would the second circuit in this scenario usually cover the second circuit inspection since the inspector is basically looking at all the same things?
Thank you!
