I want to build a post to post clothesline using pressure treated 4 x 4 posts. I am planning on securing with concrete but I am not sure how deep I need to go below ground level. I live in Michigan and the frost line is 42" but that seems overkill. Anyone have any experience with this?
It depends, but 2-3 feet is likely ok
I have build many decks and fences and in doing so I have had to set a lot of posts. My standard response would be to a 4 foot hole with a 10 inch diameter construction tube but that would definitely be overkill.
You need to figure out if you want to be able to remove them at some point, if that is the case definitely use construction (Sono) tube. Or if you plan on doing something else with the posts, ie flag pole, net for volleyball or badminton ... Also length of line will be a consideration.
Depending on the width of your footing I would say that anything in the 2-3 foot range is likely a safe bet but again remember there are many variables in play and it is always easier and safer to over build and you can be sure it will last forever. It never hurts to check local building codes, while you may not find much specially about posts for clothes lines you many come across something that helps.
| improve this answer | |
  • I definitely will not be removing it or am planning on utilizing it for any other purpose. I was thinking the same as you with the 2-3 foot range. – Steve Salowitz Apr 17 '17 at 20:32
    Well in that case, happy digging – Gareth Shepherd Apr 17 '17 at 20:51
