I have just moved recently, and I noticed that the doorbell does not work. So I tried to troubleshoot it myself. I use a multimeter and then
  1. connect both probe to the transformer it gives 16V which I assume is a good sign
  2. connect both probe to the chime, it also gives 16V (eventhough I dont press the doorbell button), so that means voltage is running through
  3. open the doorbell button and touch the probe to the 2 wire inside the doorbell button (I meant I unscrew it from the button and wire directly to the wire). It does not give me any voltage, well maybe around (0.3 or 0.4V)
What could be the problem in this case? is it the wiring or the doorbell button itself?
I figured if it's the wiring that is broken, how can the chime and transformer have 16V because theoretically, nothing is connected?
Thank you
  • Try unhooking the doorbell button from the wires and measuring the voltage between the wires... Apr 15, 2017 at 19:23
  • Yes, That's what I did.. and the voltage is around 0.3 or 0.4V.
    – Andy
    Apr 15, 2017 at 19:32
    Put your meter on resistance, and measure the resistance across the doorbell button when a) not pushed and b) pushed (of course, make sure it's not hooked up to the doorbell circuit when you do this) Apr 15, 2017 at 19:35
  • Touch the wires together and see if it chimes.
    – SDsolar
    Apr 16, 2017 at 2:27
  • Some door bell buttons have a lamp so there may be a resistance when the button is not pushed but it should be close to 0 with the button pressed.
    Jul 20, 2017 at 23:27
Generally the chime will have a solenoid that gets pulled or pushed when the circuit is completed. The solenoid bangs against the metal and you hear the nice chime. [I thought these were 24V circuits - so be sure you check your door bell system out and verify that first.
Check your voltage on the solenoid - you can check resistance with no power attached (should be some low ohms around 4 ohms probably.) When your door bell button is pushed voltage will flow from the Transformer into your solenoid - so checking the voltage at the solenoid will provide an answer as to what is working and what is not working.
You should be able to measure your 'voltage drop' at the solenoid when the doorbell circuit is made. Use Ohms Law - the voltage you know is 16V, the ohms is the resistance of the solenoid. Your solenoid even though it is an inductor has resistance - so it is your equivalent to a resistor in the example link.
Here is a quick link: http://www.wikihow.com/Calculate-Voltage-Across-a-Resistor
Some things to keep in mind: 1: Solenoid sticking - clean it and use graphite lock type lubricant. 2: Solenoid open or shorted.. 3: Transformer not working or "Overloaded" - too much current draw causes the voltage on the transformer to drop and it will not be able to pull in the solenoid. This indicates either something shorted - or a wrong doorbell chime, or a transformer that is simply worn out. 4: Doorbell switch bad .. or too much resistance - simply put one wire to the other and see if the thing works - if it does the switch is bad.
