I'd like to demolish concrete porch.
I’d like to demolish: - the concrete stairs (it’s about 3’x3’x3’) - the slab (about 3’x5’x5", all cracked with rusty rebars) - the 2 brick columns - the metal rebars and the T-shaped metal pieces on top of which the slab is placed - the upper part of the wall (I think it’s made of cinder blocks) that’s behind the stairs (in pic 6)
Here is a Dropbox link to the pictures.
The whole porch is going to be re-done in wood so no need for any of the pieces.
I'd like to keep the concrete step underneath the door if possible.
How this can be done? What tools to use? What approach? How long would it take?
    Likely an 8Lb sledge would be enough, but those stairs, are they solid or molded? Apr 11, 2017 at 21:04
    Good question. How do I tell if they are solid or molded?
    – Peter
    Apr 12, 2017 at 0:47
  • Looks like you have access to back of stairs. If hollow, that cinderblocky looking stuff should chip out pretty easy. Up on the front side of the stairs, a not too overzealous whack with a sledge could return a hollow sound. If not, a putting a chisel to that crack along the side of the steps should tell you what sort of mass your dealing with. Apr 13, 2017 at 0:29
  • No access to to the back of stairs unfortunately. That's separate wall of (I think) cinder blocks. But I can try to put a chisel in the crack, great idea.
    – Peter
    Apr 13, 2017 at 3:00
I'd budget two or three days if you're by yourself. The stairs will likely be the most time consuming. The slab is going to be obnoxious primarily because it's over that hole. It doesn't look like you can fit staging in there, and a ladder is problematic because falling debris can knock it over. I assume the dangers of demoing the slab while standing on it are self-evident. It's hard to say without a good look, but I suspect working backwards and into the door may be the best bet.
The Tools
  1. Three pound hammer - You're going to want a short-handle sledge for chisel work at some point, and three pounds is a good compromise. Nailing hammers (12-26 oz) are a bit too light and five pound hammers are a real workout if you're not used to them.
  2. Masonry chisels, two - You'll want flat and pointed, the exact sizes and shapes depending on budget and what's in the store.
  3. Goggles, not optional - No way a chip doesn't hit you in the face at some point.
  4. Long-handled sledge, optional but pretty damn handy
  5. Angle grinder, a big help - Really the cheapest tool to reliably cut both masonry and steel; something in the 4" size with both metal and masonry cutoff wheels. The fibrous disks wear out quickly, but they're probably a bit more forgiving than the diamond wheels if you run into steel accidently. Otherwise you'll want at least a hacksaw or reciprocating saw to deal with the rebar.
In addition to the short list you'll probably want to rent an electric demolition hammer for one day. Apart from the obvious labor savings it's good insurance for the stairs; you won't need to buy more tools if they're exceptionally difficult to break down.
The Plan
  1. Bar the upper door. You really should put a railing on the outside across the opening, but I get that it's brick and you don't live with an OSHA inspector. You should still consider at the least a sawhorse inside blocking the door so nobody marches out forgetting that the deck is gone.
  2. Score the slab along the house. Make a shallow cut parallel to the wall to encourage the slab to break rather than drag bricks out of the wall.
  3. Carefully remove the slab. It looks like your best bet is to work carefully from the stairs, ground, and doorway to chip away at the concrete. Just don't work underneath or on top of it!
  4. Once the slab is reduced enough that you won't kill yourself, cut off any large remaining pieces of steel. At this point the stairs and columns should be freestanding.
  5. The stairs look to be free of the house so removing them is a simple matter of breaking them into small enough pieces to lift. Electric hammer, cuts and a long-handled sledge, judicious application of a pointed chisel are all valid approaches.
  6. Score and smash is your best bet with the partition wall, though it looks like a pointed chisel in any of those cracks would brink half of it down. If you want to save a portion it's best to work your way down carefully removing small pieces.
  7. The brickwork can be dismantled with a masonry chisel applied to the mortar. Running a cutoff wheel along the bed joints can help if the going is too difficult.
  • Thanks you, what I was looking for. Would something like Dexpan (homedepot.com/p/…) be worth looking into for the staircase or would a 90lbs electric jack hammer plus other tools be more practical?
    – Peter
    Apr 13, 2017 at 1:13
  • Time and tooling are factors with the expanding agents. It's at least a day letting it set, longer if you need a second application. Dexpan also suggests 1.5" holes spaced 1' apart. If you need to rent a rotary hammer to drill the holes you may as well go with the demo hammer and be done quicker. Apr 13, 2017 at 23:51
