Trying to take apart a bed frame. Does anyone have any idea on how to open these?
Thanks.
Try placing a screwdriver into the slot, rotating the cam a quarter turn counterclockwise, then separating the joint.– Matthew GauthierApr 11, 2017 at 6:18
1Rather than a cam-lock, that (the black part in the brown part) looks like a bolt-head you may need to turn many times (1/4 turn at a whack) to disconnect. Not quite the usual bed-bolt.– EcnerwalApr 12, 2017 at 2:01
1 Answer
Just about the only thing you can do is turn the cam 1/4 turn at a time and keep trying to separate the joint. These are usually easy to lock and unlock is why they are used. But if they were over tightened ever or the wood was repaired or even wrong in size like from a factory defect, you could find yourself turning these things back and forth all day because they will only unlock in one specific "sweet spot".
I know these cams can be frustrating and even cause people to second guess clockwise,counter clockwise, lefty loosey-righty tightly and so on.
