We took up old ceramic tile and found no cement board or other underlayment material underneath. However, I did find that the previous installer had put another sheet of 1/2 plywood over the 3/4 inch plywood subfloor. No nails or screws in that top sheet of plywood. Guessing they just glued it to the 3/4 inch subfloor.
Is this adequate to install new 12 x 24 inch porcelain tile if I screw that top plywood onto the subfloor, ensuring the screws are every 6 to 8 inches apart and not screwed into the joist?
Or, do I need to get rid of that 1/2 plywood sheet and install cement board, or something like Ditra?
Thank you. Kicknback1
I suppose if the floor won't get wet, it would be perfectly fine to just lay the porcelain tiles directly over the plywood with thinset.
If the 1/2 top layer plywood was glued to the 3/4 plywood, then it's effectively a 1-1/4" plywood.
  • Thank you Rollo. What I found strange is that in one of the rooms (we're doing 3 rooms that all flow together), which is a bathroom, they didn't use cement board. That may be the one room that I get rid of that top sheet of plywood and replace with cement board (attached to the subfloor with thinset and screws to the subfloor).
    – Kicknback1
    Apr 10, 2017 at 20:34
Ditra works fantastically well, when you follow the instructions... and it demands slightly less plywood than some other underlayments. I've done a few bathrooms, a laundry room, and a couple kitchens with ditra. Not a single crack, even in locations where you used a little less ply than called for.
There's a ditra install manual on the web, just plug in your values and you're good to go.
  • Hello, and welcome to Home Improvement. Good answer; keep 'em coming! Jan 27, 2019 at 12:47
I would not install porcelain tile on plywood. I'd only use a cement board.
I would not use thin set if it needs to be waterproof.
However, deflection is the key element in the performance of tile. Too much deflection and the tile (and/or grout) will crack. Therefore, I'd check the size, spacing and span of the floor joists before starting.
