I nicked an electrical cable while doing a plumbing repair and so need to fix it. I previously asked about repairing the damage in place, but there are receptacles 6-10 feet away on either side of the damaged wire, so it may not be too difficult to just pull new wire. Most of the wire is run horizontally through the studs, which is great, but it will at least be stapled at both boxes (and possibly more). The horizontal run is ~18" up from the floor, while the receptacles are ~6". There is also an inside corner the wire is run through. Wire is 12/2.
Is it possible to use the existing wire to fish the new wire, even though the existing wire is stapled? Would I need to open up the wall to remove the staples?
I found a related question, but that pertains to telephone wires which sometimes use different staples than electrical wires.
