I am having an incredibly annoying vibration/hum through my wall/ floor. It is Reverberating at about 36Hz. I am an audio engineer so I have the equipment to analyze it. It happens randomly throughout the day but mostly in the evening / night while I'm sleeping. It happens for exactly 30 minutes to the second. Sometimes it doesn't start again for many hours sometimes it will start again after a 10 minuet break but still always 30 minutes. I am in the 3rd floor of an apartment building. I have run around feeling pipes while it is happening to see what this could be. It's not the air conditioners. Sometimes it goes of 7 times a day. Sometimes it goes off 3 but always during the night. It sounds like a motor or compressor I can't sleep. I can't tell anyone when it's going to happen to call anyone to come out. I am going crazy. Please help!
11
    My guess is that it's a vibrating chair.
    – Edwin
    Apr 9 '17 at 22:37
    You say exactly 30 minutes at various times...My guess is solar heat transfer to storage unit. Any solar units on roof?
    – Lee Sam
    Apr 10 '17 at 6:19
    That vibration could come from anywhere in the building, transmitted thru the solid frame (joists, beams, etc),so next to impossible to trace. What's in the basement? Laundry machines, for example? (or the always-popular "space aliens" ) Apr 10 '17 at 18:02
    If the washing machine is turned on in my house, the same phenomenon occurs. The washing machine is located on the second floor, and it provides a constant hum when turned on, and the entire upper floor of the house vibrates/shakes. Seems very similar to the situation you are describing.
    – Hammergold
    Apr 15 '17 at 12:47
    @AliMcGuire I think you are dealing with a pump motor of some sort - always 30 minutes says it is not really random or any person , but rather a controlled device. You did not say how many times during the night it cycles but you have timed it. It could be a compressor motor - oddly running 30 minutes filling a tank. Ask the apartment maintenance staff if they have any such pumps or compressors in the building. Boiler in the building circulating motor??
    – Ken
    May 9 '17 at 3:24
Could it be a sump pump in your building and the discharge pipe is touching framing.
