I just got my water heater fixed as previously it wasn't heating up water. When I turned on the water heater later on, at first there was nothing wrong since it takes time for heating element to heat up the water to a hot temp. But once the water started to really get hot in the tank, then water started spurting out profusely, almost as if someone turned the knob to let some water out but not to the full shower 'strength'. It just kept spurting out really hot water until I decided it would be safe to turn off the heater until I figure out whats wrong. I'm guessing theres something wrong with the pressure seal on the shower head? Might it be that the pressure in the water tank is forcing out the hot water as the water begins to get very hot? Also, is it safe for my family to take a shower while its like this? Update: I realize the problem might actually be with the shower head. After inspecting it more closely I noticed its a bit busted up and its not spraying water well. One of my family members must've dropped it on the floor this morning. But I'll get a new shower head soon and we'll see if that fixes the problem.
  • recommend closing as "unclear what is beingasked" Apr 6, 2017 at 17:57
    Where are you located? Plumbing differs around the world so this will affect answers. Is you water heater gas or electric?Does your water heater have a T&P valve installed?
    – Sean
    Apr 6, 2017 at 18:32
I just got my water heater fixed as previously it wasn't boiling water
A water heater should not raise the temperature of the water to 100℃ (boiling). You should not have any boiling occurring anywhere inside your household hot-water systems (excluding vessels used for preparation of food or hot drinks such as kettles and saucepans).
In my part of the world, a home water heater has a thermostat that determines the maximum temperature of the water, this thermostat cuts off the source of heat when the water reaches the set temperature. Perhaps you have a faulty thermostat, the wrong type of thermostat or one set to an incorrect value?
There are two main health aspects of water heating systems:
  • preventing pathogens multiplying in the water
  • preventing people from being scalded
The first, primarily concerning Legionalla, is prevented by storing water at ⋝60℃ and ensuring it is ⋝55℃ at outlets.
The latter conflicts somewhat with the first. You need lower temperatures to prevent scalding of vulnerable individuals (babies, elderly, etc) The UK HSE suggests water at the outlet needs to be less than 44℃ to prevent scalding.
One way to reconcile this may be to have a thermostatic mixer close to the outlet - this will mix a small mount of cold water with the hot to reduce the temperature slightly. One place where you normally find these sorts of thermostatic mixer in the UK is under washbasins inside washrooms for the disabled. In most houses though, the temperature is just a compromise between these two risks and is not regulated using a thermostatic mixer.
Many showers include a thermostatic control that prevents the shower producing water hot enough to cause scalding.
As Mike Baranczak commented, this is almost certainly not the cause of your problem.
In the types of shower familiar to me, the shower head plays no role in shutting off the supply of water. You might have a shower head that can be rotated to produce various patterns of spray, some feeling softer and some feeling more vigourous, but this doesn't much affect the flow rate or shut off the flow.
You shut off the flow of water using a valve much lower down than the shower head. This valve is part of the shower controls that you use to set temperature and flow rate. There is a valve that is either directly operated or operated by solenoid (often the case in electric showers which use electricity to heat an insulated element that heats cold water passing through the shower unit)
The water heater should have some means of handling excess pressure. Often it will have a pressure relief valve that vents excess pressure safely. Some older designs have the pressure regulated by a header tank.
If the pressure is high enough to force excessively hot water past a shut valve, there is probably something wrong with the heater, the valve or both.
If you need more specific help, you could edit your question to add details of make and model of heater and shower contols and shower head, together with photos of those items.
  • Hmm... Sorry if I used the wrong words. I don't think my heater raises the temp to 'boiling' temp. I was just using simpler words, I've already made corrections above. But now I realize the problem might actually be with the shower head. After inspecting it more closely I noticed its a bit busted up and its not spraying water well. One of my family members must've dropped it on the floor this morning. But I'll get a new shower head soon and we'll see if that fixes the problem. Apr 6, 2017 at 11:17
  • @DavidJrGbadago "boiling" still appears in the title of your question. Also what's unclear is the position of the water valve or shower control. If the water should be off, and the shower is "spurting" hot water, as your question seems to indicate, then the water is most certainly getting too hot.
    – Tyson
    Apr 6, 2017 at 12:52
    @DavidJrGbadago The shower head isn't supposed to shut off the flow of water - the faucet valve does that. If your head is messed up, that's a separate problem. Apr 6, 2017 at 20:00
