Our radon system is right under/outside our 6 month old's bedroom. Over the fall and winter I never heard it but now it is running a lot and it is very loud and it is affecting our daughter's sleeping. We never used the room she is in last spring so I do not know if it ran a lot last year.
Is there a way to either: A. Reduce the system noise? or B. Schedule when the system goes off (i.e. have it run during the day rather at night)?
Thanks for your help.
UPDATE: The guy came out said the fan was good but the unit was touching the house so any vibrations were transferring into the house. He also thought the system could be a bit louder than usual due to high ground water levels from excessive rain of late. He repiped it to move the fan off the house and put foam between the pipe and the house. It was under warranty so that was a plus.
