I have read the wiring configuration for a regular switch. Is this the same configuration for a dimmer switch? One switch, several lights. I don't need a three way switch do I?
    If you have only 1 switch on the lights a standard dimmer is all that is needed. (SPST) Single pole single throw. – Ed Beal Apr 5 '17 at 2:04
A dimmer switch can replace a regular switch as long as the lights/light bulbs are dimmable.
A three way switch is a way to have two switches control one light.
