I have a kitchen with 9"x9" vinyl floor tiles that I have just found out contain asbestos. Though they are at first glance in sound condition (only a very few small chips, all well-adhered, etc), looking closer there is a fair amount of scuffing and small scratches from everyday wear and tear which with 2 kids I do not like at all. All that abraded material has to go somewhere...
The long-term plan - when we can afford it - is to rip out the kitchen and probably put on an extension. But I want to do something now to stop the wear and tear on the tiles - and ideally encapsulate them. How can I best do this without (a) tearing out the existing kitchen units and (b) making a future remodelling much more difficult? This area might eventually be carpeted, tiled or lino. I don't much care what it looks like in the meantime. It is VAT on top of concrete; there's no visible black glue so I imagine they were peel and stick. Options I have thought of:
- Epoxy floor paint. Would do the job, but I understand it's very hard to put anything else on top of this later without scarifying the surface (bad idea on asbestos!) - and presumably this would make removing the tiles really hard too
- Polyurethane floor paint. May be better to lay new flooring on later, but will it adhere, and it also sounds horrible to work with (respirator needed?)
- May be a crazy idea, but can I just get some cheap vinyl flooring and lay it without sticking it down?
- I can't see trying to put down any form of screed around the existing units working
- How much difference would vinyl floor polish/sealer make? As far as I can tell, these are usually wax-based so are unlikely to add a lot of abrasion resistance.
