I live in UK in a 2-storey semi-detached house built in 1946. We are in the process of building an extension to the side of it - with garage on the ground floor and a bedroom above the garage. The shell is already built and the internal fitting is still in progress.
I am about to install an IP video security system with 7 cameras around the house. All cameras are PoE, that is only require ethernet cable for connection. The easiest thing for me is to route a bunch of network cables into the garage, install two 4-jack faceplates and route all cables from the cameras into the garage.
The house is already fully wired with CAT6 and a cupboard under the stairs contains the patch panel and the switch. The garage is adjacent to the cupboard, and there is already a hole through the wall, through which electrical cables are routed. The hole is big enough for me to route additional 8 CAT6 cables - so it's very easy to get ethernet connections into the garage. (CAT6 cable I am using is fully shielded - each pair is foil wrapped and the whole cable is in a metal mesh under the top insulation - therefore I am not too worried about the interference.
Now, convenience-wise, it's best for me to install these ethernet jacks in the garage closer to ceiling level (say, a foot or so below the ceiling). This way there will be the least amount of cabling in the garage.
The question I have is whether I would have problems with building regulations - with connection point so high up. Any suggestions?
  • I don't know for your locale, but I would doubt any trouble - we often put them in the middle of the ceiling (best place to mount an access point.) In general they are much less regulated than electrical outlets.
    Apr 2, 2017 at 21:03
