I would like to build a shelf capable of holding a maximum load of cca. 60Kg. The image show the placement of the shelf.
Below is a conceptual drawing with the dimensions.
The image shows the brackets serving as the main support for the shelf. They are capable of carrying far more than 60Kg but have a limited width.
This makes the "critical surface", the weakest link of the construction and the part most prone to breaking.
How would you approach this problem?
Really I think you need bigger brackets. Otherwise I'd consider ...
  • Make the wood thick
  • Select a strong species
  • Align the grain across the width (less chance of 40cm splitting off)
  • Extend the brackets using ~60cm pieces of wood as an intermediate support.
  • Screw a support rail along the wall up to the window.
| improve this answer | |
