I have a two 3-way switch switched outlet.
I want to remove both switches and replace both with blanks, thus capping the wires in the box so that the outlet is always on and there is no switch in between.
My house was built in 2001.
United States electrical code.
Using the diagram below... Someone on another site suggested capping the Black/Red/White of Switch A together, and then capping the Black/White/Black of Switch B together to remove both switches but keep outlets powered all the time.
UPDATE:
I capped all three wires (Red/Black/White) of Switch A but left Switch B alone for now. This resulted in the outlet always being on regardless of Switch B's On/Off position.
Tomorrow I will try the same with Switch B, and I assume this will work. Would be nice to have clarification to make sure this is not going to cause a fire.
