My lawn retains a lot of water and I've read that using a fork to put holes in can help.
I've already started but I'm afraid to go too deep just incase i got a pipe.
How can i work out where the pipes are?
Sign up to join this communityMy lawn retains a lot of water and I've read that using a fork to put holes in can help.
In typical UK homes, critical infrastructure, like electrical power, gas, water and sewage should be deep enough that there is no danger of hitting it with a garden fork from the surface. About two or three feet would be typical I believe. You can check the depth of your sewer pipes at the manhole located near your home.
For example, according to Anglian Water
There is a minimum and maximum depth at which service pipes should be laid:
Minimum depth is 750 mm
Maximum depth is 1350 mm
750mm is about 2½ feet.
In other countries the situation may differ of course. If you have a very old home or unusual terrain you might need to take more care.
In addition, I don't think you could realistically puncture any of these with a manually operated garden fork. I assume you have not sharpened the tines and are not using a club hammer to force the fork into your lawn.
Tracing underground services from the surface needs expensive specialised equipment (random example, another) which can be hired (random example).
