I have my interior wall exposed and would like to rough in some outdoor lights without actually cutting into the exterior siding right now. I plan on replacing the siding this summer.
Is this possible? Should I do it this way? What sort of boxes would I use for this? New work?
    So long as you trust your locating ability :-), no reason not to mount a box and wiring now. I'd recommend not connecting any wires to a hot source until you're ready to mount fixtures on the exterior. Mar 24, 2017 at 17:11
  • I think if you used something the mark the location of the box that's visible from the exterior you'd be ok. Something like a machine screw/bolt through the siding, covered with a bit of silicone or something. Otherwise, how would you accurately locate the roughed-in box without stripping all the siding? Mar 24, 2017 at 18:04
  • If you use an old work box you could do it. Nailing a box behind the sheeting would leave to large of a gap when the new siding is put in unless an extension ring is used.
    Mar 24, 2017 at 18:47
