RE: Samsung Front Load Gas Dryer. DV42H5200GW. T his should have been an easy install, but plastic gas fitting seems to have cracked. I was just connecting my existing gas line to the dryer, and I may have over tightened the fitting as I heard a slight crack or squeak and now the plastic fitting on dryer is turning as I turn the line fitting. I will now remove the back panel to investigate, but I cannot afford to hire a pro.
closed as unclear what you're asking by ThreePhaseEel, Daniel Griscom, Tester101 Mar 27 '17 at 11:04
Please clarify your specific problem or add additional details to highlight exactly what you need. As it's currently written, it’s hard to tell exactly what you're asking. See the How to Ask page for help clarifying this question. If this question can be reworded to fit the rules in the help center, please edit the question.
It's possible that the plastic part is intended to spin like a female garden hose end does. To check for leaks, drizzle soapy water over the connection. Without photos or a better description of the problem I can't say much more.
  • Sorry, I meant water line - this is a gas dryer with a steam option. So this is the water fitting that has broken. – Ellen Mar 24 '17 at 14:19
  • Please edit your post to correct that. – isherwood Mar 24 '17 at 15:28
