We have a 100 year old house that has an encapsulated attic that covers not only the house but over the front porch as well. There is no insulation in the attic at all. Since we are preparing to insulate my question is should I build and insulate a knee wall between the house and the porch or just insulate the attic over the porch.
    Welcome to SE. You're asking a question that calls for more information. Is the porch heated? Why do you think you need a knee wall? What type of insulation will you use? Please edit your question to provide detail. – isherwood Mar 22 '17 at 19:45
  • A few questions, are there soffit vents in the porch canopy? If so then the air is drawing thru it and making a kneewall will cause the area behind the kneewall to become an unventilated spac. If a kneewall is added you will need to add vents to each end of outer wall to vent knee wall area. Attic insultaion on the floor of the attic will still be needed alsonin the area behind kneewall. Also do you have a ridgevent? Or gable vents? These are all questions that have to be factored in. – David Moritz Jun 25 '17 at 14:35
  • Voting to close as unclear. Questions haven't been answered. OP hasn't been around. – isherwood Aug 30 '17 at 18:45
If I understand the extent of the attic you describe, there is no need for a vertical termination knee wall - you can simply end the insulation where the exterior wall meets the bottom of the attic space. The insulation envelope you are creating just needs to match the footprint of the finished interior ceilings below.
| improve this answer | |
You only need to insulate the area over the "heated" spaces. If the "porch" is heated, then you'll need to insulate it too, if not, then don't.
There is no need to build a wall between the "house" area and the "porch" area. In fact, it might be best not to build a wall so the attic ventilation remains the same and continues working in the same manner. Building a wall could block air flow.
When you add insulation, you'll need to consider: 1) How much? 2) what kind? 3) with or without a vapor barrier? 4) adequate attic ventilation? But those are maybe separate questions for Stack Exchange.
By the way, around here, commercial insulation contractors can buy and install the insulation cheaper than us home do-it-yourselfers. I'd check with them before I tried to do it and get those little fibers up my nose.
