My question is "what gauge wire do I need to replace the old wire?"
There is no power from the source.
What gauge wire should be used to run the new fan?
    Um...where are you on this planet? Also, are you talking about the cable from the wall switch to the fan, or the fixture wiring inside the fan itself? – ThreePhaseEel Mar 19 '17 at 22:37
  • Are you replacing the wire because there is no power? If so, why do you think the problem is the wire? – Tyson Mar 19 '17 at 23:55
  • you need to give us a detailed description of what the problem is, what does " no power from the source" mean exactly. you say replacement, was there a problem before you replaced the old fan.? – Alaska Man Mar 20 '17 at 3:04
