If the brick has zero movement year round, buy a high quality exterior rated thin set mortar. And simple follow normal procedure for adhering tile to a wall. A good thin set allows for enough movement that winter, and water, shouldn't be a problem if the substrate is stable.
If you are less confident in the wall's stability then I would suggest a tile membrane and use an exterior rated thin set for both sides of the membrane. Adhere the membrane to the wall, then the tile to the membrane. The membrane will allow for 1/8 inch movement parallel to the membrane without cracking the tile.
Example Tile membrane
https://www.lowes.com/pd/Schluter-Systems-54-sq-ft-0-0008-in-Orange-Plastic-Commercial-Residential-Tile-Membrane/4717375
http://www.menards.com/main/flooring-rugs/tile-stone/tile-installation-maintenance/tile-surface-preparation/prova-mat-reg-waterproofing-membrane-54-sq-ft/p-1444438746920-c-6590.htm?tid=-2511184973115174626
For grout you have the standard choices. Cement based, Epoxy, Urethane, and Resin grout. I've used cement, epoxy, and urethane. Epoxy and urethane grouts are good for slightly volatile environments, but they do cost a lot more than cement. A high quality cement grout will probably meet your needs in most cases.
Also be aware that ceramic tile isn't waterproof. Water will seep through it and drain away. As long as it isn't being sprayed with water at -20 degrees Fahrenheit, it should survive the outdoors just fine.
